What gauge is stock positive cable 05 Escalade?
Long story short, I replaced mine with 0 gauge before I knew about these trucks having the seld adjusting alternator voltage.
Now I want to change the 0 gauge to whatever stock gauge it had.
Any ideas? I assume all gm trucks around this year would have the same gauge for the positive battery cable
Current Setup:
Mechman 370a Alt 4 pin
DC Triple Alt Bracket
XS3400 Battery
4 Ampere 6.5 components 4 tweets
Ampere 150.4 way
Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms
DG Roll Pan
LED License Plate Lights
8 gauge,
so why are you wanting to change it back? it would still be best to have 1/0 even if it self regulates.
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
Thanks!
Charges too high and I am going to run stock alt for cars electrical and two mechmans for audio.
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
Thanks bill! BTW my A-pillars look amazing, I just actually dropped my truck off to get the headliner/pillars wrapped in suede so I will put some pics up this weekend.
Got a link to the factory one? Ive been trying to look but couldn't find it.
Thanks!
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
When you do the big 3 you should just be adding to the stock wiring
Clarion cz702
Ssa evil mids and tweeters
ppi 900.4
2 zcon 18s
Taramps 10k
3 big dekas 1 xs
3 runs of 4/0 and big 3
300+ amp ohio generator
155.7 on dash at 36 (peak) 152 at 25
Thanks!
No problem, wasn't sure who I made the pillars for lol you might ge able order a stock charging wire through any local auto parts store
it's not the wire size that's causing the alt to charge to high. It's because you removed the stock, that was probably attached/ran through some type of sensor.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
You guys are right, so I am going to either get 8awg and run it through battery current sensor and fuse it or get stock wire which i actually dont think is fused. Would the big 3 help on the regulated stock alt? I was under the impression it wouldnt really be beneificial. Id rather run two extra alts and keep stock alt for the trucks electrical not audio. Thanks again guys for ant imput, tons of knowledge on these forums!!
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
