diegoclass2010 Posted October 2, 2016 Report Posted October 2, 2016 PL Glue X8... done deal... bonds to practically anything, supper strong , fills any gaps big or small and it expands during curing time so you get an air tight seal.
Skullz Posted October 2, 2016 Report Posted October 2, 2016 I just have the store cut my sheet to the sizes i need for free, while the cuts may not be exactly the same length if the clerk isn't careful, but the cuts are straight and square. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ShadeTreeMechanic Posted October 2, 2016 Report Posted October 2, 2016 Liquid nails. Put a big bead along the whole joint on the inside. Then with a wet finger smooth it out a little to make a nice fillet. Give it a few days to dry. I did this to my kids dresser drawers after the bottoms fell out. I also glued a nice wooden computer desk back together that the neighbor was throwing away. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
audiofanaticz Posted October 2, 2016 Report Posted October 2, 2016 ^^^ Make sure to wear a glove of some sorts before you start fingering some PL. Lol
