is 2/0 wire to big for big 3?
There's no downside to putting bigger wire, unless you don't have the room for it. I'm sure the 1/0 is big enough for the amount of current required in your system. Most people only run 2/0 so that they don't have to make multiple runs of 1/0.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I have the room for it and also the wires. I have these nice copper lugs to. I just don't want this stuff laying around here. I guess I'll install it.
Battery + to alternator +
Battery - to alternator -(casing) or engine block
battery - to fender.
Is a battery - to chassis a good option for a big 4
or
engine block to chassis?
Mine is in 2/0 but it prolly doesn't need to be.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Sell it ! Make that money for other things. You won't be able to sell your current wires, they'll lay around too !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Current wires will be made to work on my dads 4 Runner. I just rather use the 2/0 wire being that I have a bigger system then he does. My system is only about 3300 RMS. His is 1600 rms. His light dim alittle so the big 3 will work for him. I just want to make sure that 2/0 wire is perfectly fine which as per you experts, it is.
Thanks a lot.
How much ground is to much?
So this is what i did in 2/0 gauge wire.
Positive:
Battery to alternator.
Negative:
Battery to factor fender
Battery to direct chassis
Battery to alternator casing
Engine block to direct chassis.
Im assuming this is all fine? Every negative was grinded to bare shinny metal.
So is this all fine?
Is there any reason that doing alt ground-to-battery ground terminal is BETTER than going alt ground-to-frame? I would think that the alt having its own ground would be prefered? Rather than sharing ground wire with the battery, right? Just wondering if one method is superior to the other with grounding alt. Not thread jackin, i think this info might help OP also.
And also OP ive heard its good to upgrade ALL grounds on ur engine, for performance. Helps make sure all ur electricals within the engine have clear paths for current to run. Like for spark plugs firing and such. Probably dont need 2/0 for that lol but sounds like you probabaly have other extra wires layin around, maybe some 4awg or 8awg. Anything is an improvement from the tiny ground wires car manufacturers install on our cars. Just passin on some info i heard, goodluck.
I want to swap my 1/0 to 2/0 gauge on my big 3 just because I'm bored and have these cables on hand. Will I come across any issues like maybe engine noise through speakers or other electrical problems?
You'll be fine. This is some shit I would do to just because I'm bored too, lol
  • Who's Online   0 Members, 0 Anonymous, 4509 Guests (See full list)
