Mounting 1 amp underseat and 1 in passanger foot-well
Holy crap. y is this thread still going. Just glue some mdf down and mount the amp to it. People have told u wat to use instead of screws.
Make a spacer and use short self taping screws. Nothing wrong with under the seat mounting IMO. But it sounds like your best bet is a shop to install your system.
Built spacers with 3/4 x 3/4 aluminium square tubing to get amps off of floor. Dual purpose, hides wiring and helps keep amps cooler.
Plus, added security. Hard to steal what you cant see or get to.
You could glue MDF to the floor under the carpet. Then screw the amp through the carpet into the wood.
Pioneer 80PRS
I plan on using a technique similar to this in my car and I have used similar ideas to float mount amplifiers in cars trunks before
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
That is a good idea, spacers! Instead of a whole board. I think im gonna mix the two best ideas i like and use adhesive to secure the spacers. That way im not gluing a whole sheet of something to the body, just a spaceing bar. Thanks man. Thatll be perfect for my one amp under the seat.
