Ext cab window rattling.
Are they this type that pop out a little? If so, you can often shim and adjust the latch to clamp down tighter.
1995-2004-tacoma-2000-2006-tundra-extrac
That is the sort of style that mine were, and I was bending the window at the corners away. The latch just isnt strong enough once you get over mid level systems.
I took silicone and sealed mine to where they can no longer open and it worked fine in my 95 chevy.
Which silocone ? I'm willing to do that tomorrow
regular black silicone worked fine up until I had 2 15's on 7k at the windown line, then I PL'd them shut and they are still held tight.
So I should go right to the PL :) 8x ?
I used 3x and never had to worry about it again. Plus with how the windows sit, if you do it right, you dont even see PL anywhere, just looks factory except it will never be able to be opened again.
Sounds good. thanks
