Hey Guys,
So let me give you a quick list of what i use/have right now and maybe you can tell me what i did wrong to have my bass knob light go to red.
My goal is to do 2 dual 2 ohm to 1 ohm amp.
2010 Camaro LT v6
Stock Alternator
Stock battery(New)
Sub Enclosure is a custom box from zenenclosure (PorteD)
Hifonics brutus brx2400.1d
Sub is 2 soundqubed hds312 in dual 2 ohm.
So i wire each sub to http://images.crutchfieldonline.com/ca/learningcenter/car/subwoofer_wiring/1-DVC-2-ohm-mono-low-imp.jpg
the hifonic amp got 2 channel i guess, 4 positive and 4 negative, I try to do 1 speaker wire wire to 1 output.
It play for like 20-20 min and my bass knob goes from green to red, It still play but i stop cause im scare the red on bass knob mean protect mode.
Any idea on what i did wrong?
Some of my friend told me to do 2 speaker wire positive goes to 1 postive amp.
It sounds like you are wired to .5 ohm maybe.
Pioneer 80PRS
Two D2 subs wired in parallel will have a final impedance of .5 ohms (which is what I think you might be wired in) but your amp is not .5ohm stable. Seems your only wiring option in relation to your amp, is wiring your two D2's in series parallel for a final impedance of 2ohms. Your amp is 1600 RMS @ 2ohm's. Also make sure your gains are set correctly with a DD1 or DMM.
Yes but that imagev is to wire one speaker to 1 ohm. You can't wire two subs to 1 ohm if they are dual 2 ohm voice coils. You can do 4, 2, and .5ohm.
You can't do 4 either
