Hissing noise from speakers
Cant seem to get to the bottom of this.
Got a hissing noise from my amp'd speakers, hissing noise is there even when the volume is set to 0.
When I'm driving the car hard I can hear the alternator while but that's at like 5k rpm
I have tried the following and still no luck:
Different amps
Have grounded the head unit straight to the battery
Ground head-unit rca's to head unit
Changed rca leads
Have tried a ground loop isolator
Any help would be great.
Many Thanks
p.s. cant remember correctly but I"m sure when I had the rca's out of the head unit the sound was still there. (will confirm this once the weather clears up)
is it coming from all speakers, or just tweeters, just mids, etc? Has it always done this, or did it start recently? You did the big three? Where are all of your grounds at? If you took the 3Sixty.3 out of the circuit and it was still there, it's either the HU, the location of the RCAs, or the amp (high noise floor, bad ground). Also, what amps, HU, and speakers do you have? Some amps have been found to have an awful noise floor.
I only have my fronts connect so far, can only hear it in the tweeters.
big 3 is done
all wires are grounded with 4ga to a diso block and then a 0ga back to the battery
3.sixty out of the circuit hissing is still there
have tried different rcas over seats
amp is a sundown 125.4 sax
headunit: http://www.eonon.com/Android-Car-GPS/Vehicle-Specific-GPS/GA5153F.html
speakers hybrid audio clarus 6.5
Check all your grounds even if you think they are perfectly fine you might not have a good enough connection and causing the hiss.
Another thing to do is ground your rca's on the H/U to prevent a problem from there.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Does it still do it with the gain all the way down?
Pioneer 80PRS
