ShadeTreeMechanic Posted December 23, 2016 Report Posted December 23, 2016 A dashboard array would be cool. What amp would you put them on? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
dolarbilz Posted December 23, 2016 Author Report Posted December 23, 2016 A dashboard array would be cool. What amp would you put them on?Zapco st4sq I have a pionner 99prs so I'm pretty flexible on crossover
dolarbilz Posted December 27, 2016 Author Report Posted December 27, 2016 Looking for more or any input still.
boom50cal Posted December 27, 2016 Report Posted December 27, 2016 I haven't ran those exact drivers, but I've been running some Tymphany 1 inch tweeters that I got from Parts express for about a year. They are great quality and cheap ($15/ea). I recommend the brand to anyone. If you have good results with the 2 inch, please share with us. Those spark my interest. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
dolarbilz Posted December 27, 2016 Author Report Posted December 27, 2016 Guess I'll be the guinea pig.ill order one to see how they will fit and sound
s5300 Posted December 27, 2016 Report Posted December 27, 2016 I'm confused at this 15 watt RMS. Isn't that like, low?
dolarbilz Posted December 27, 2016 Author Report Posted December 27, 2016 I'm confused at this 15 watt RMS. Isn't that like, low? Yes it's low but when running four drivers per channel it will be fine..
s5300 Posted December 27, 2016 Report Posted December 27, 2016 I'm confused at this 15 watt RMS. Isn't that like, low? Yes it's low but when running four drivers per channel it will be fine.. So like, this is the type of driver you'd run with multiple in a configuration? Never just one per side? Makes sense. I haven't dabbled much into the mids/highs world.
ShadeTreeMechanic Posted December 27, 2016 Report Posted December 27, 2016 Running them band pass or high pass will help with power handling. You would be surprised how much clean power can be run to a driver. Music being dynamic causes less power to be developed by the amp to begin with. Just don't try to play pink noise at high volume.lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Soccerballzs Posted December 27, 2016 Report Posted December 27, 2016 Use a 3 inch mid and tweeter and be done with it. 2 inch fullrange still lacking the upper high end and low end. You will lack midbass. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
