Could my volt meter drain my battery over night?
I have my volt meter wired to the power on my sub amp and I noticed it never turns off could this small amount of power drain a battery ?
this is my first build, i have been waiting 4-5 years to have this done
95 chevy 2 door tahoe 5.7
Xs power d3400
Singer 275amp alternator
Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders
Sundown SAE-1500d
Mbquart onyx OA800.4
Stinger 4400 series RCAs and stinger volt meter
Fi Q NEO 18, 7.5 cubes tuned 32hz
Pioneer MVH-X690BS H/U
Kicker CSS 6.5 comp sets in front doors
Kicker KSC 4x10 coaxials in rear
GTMAT and FAT MAT deadner
Xenon 10k Blue HIDs
Eventually it could I guess. It draws such a small amount of power that it would probably be ok on a daily driver. On a vehicle in storage for months, maybe not a good idea. What voltage does it read after sitting overnight?
Pioneer 80PRS
I have an xs power d3400 and idk about voltage overnight cause I just put it in a hour or 2 ago but I will look
and yes it's always cold here
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
It inlet had a power and a ground, it is xscorpiian
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
Check your voltage one night and then check it in the morning see what the drop is better be no more then half a volt even that might be to much.
IIRC most volt meters draw around 50ma. That shouldn't be enough to hurt you, but if you car's going to be sitting for more than 3-4 days I'd unplug it
If you're concerned about it you can wire in a transistor or a relay to switch it on and off with the ignition
  • Who's Online   1 Member, 0 Anonymous, 1905 Guests (See full list)
