Fusing on multiple runs
Just weird how I get different answers on this depending who I ask. Is there equation to figure this out?
tony d'amore, Steve Meade?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Fuse for what the run is rated for not higher. You could fuse for lower and see if they blow. Either way it makes no difference because it is just to protect the wire.
Pioneer 80PRS
Meh. So confusing.
So for battery runs from front to rear battery, we would fuse for the wire's rating (in my case 300A for 0 Gauge Knu Kolossus Wire).
For my DC5K Amp in the trunk going to my rear battery, I would use 250A fuses for the two power runs connected to the amp for a total of 500A (rated on the website for DC5K)?
If I were to use dual 1/0 inputs for a total of 4 power runs, would I then divide 500A by four and use 125A Fuses for each of the four run?
5 minutes ago, moh.vze.com said:
Meh. So confusing.
Personally, I wouldn't fuse between the amp and rear battery. But if you wanted to, then the rating divided between the number of runs is how you would do it.
Pioneer 80PRS
Yep 4 125amp fuses for your dc5k if u have dual inputs
2 250amp fuses for dc5k with no dual inputs
From what my consensus is for 4 runs from front to back, is fuse them to Max amperage draw.
Hmm 125A is an oddball # to find fuses for. Would I round up to 150A or down to 100A ?
I have 4 150s in mine wish Droppinhz or shca or someone sold 125amp anls
Same, and same.... Never ran a fuse from bat bank to amplifier input, UNLESS its a long ish run. The ONLY reason we fuse in the burban, is because rules require it, in the ORG we compete in. Other than that, i never have ran a fuse from bat bank to amp in. Again, unless that run was long and made its way around half the back of the rig. And if i i did dual inputs, yes, i would run half the rated on each line. Just because.  I would do the exact same SHADE. Just me, and how i do it.
Alternator output ??? This makes no sense to me. At all ...
  • Who's Online   0 Members, 0 Anonymous, 3996 Guests (See full list)
