So when I start my tahoe it barely wants to pick up. It's fine when the car is going but then, say I come to a complete stop, and hit the gas it takes a while to gain speed. The check engine light is on but I don't want to drive to autozone and get stuck. I probably will go get the light read but for now I'm looking for ideas. My guess is throttle sensor, I cleaned the throttle body last summer and my electrical is fine.
What year? Intake gaskets are a fairly common failure. If you have a vacuum leak there it could cause an issue like you're describing.
How many miles? Last tune up? If you're going road speed and punch it, what happens?
2004. I don't have vacuum lines that I know of. It's hydraulic or some shit. When i go road speed it picks up normal. It's like there's a hold up in 1st gear but no trans slip. It's a little under 160,000
There is a program called obdcom that is around $100 to use your laptop to read the codes to see what is going on. You need to read the codes unless you are good at guessing.
Pioneer 80PRS
3 hours ago, Ahmed Johnson said:
I'm debating if I should just buy the part and hope, lol. I just don't want to get stranded trying to get to the parts store
If you're going to the parts store why not make use of their scanner eh?
Is a catalytic converter
Its a fuel pump
Its the TPS
Its the Throttle pedal
Its the intake
Quit being lazy and go see what the code is or you can spend a bunch of money on parts that might not fix the issue.
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
  • Who's Online   0 Members, 0 Anonymous, 4006 Guests (See full list)
