4 hours ago, Keith77 said:
Quit being lazy and go see what the code is or you can spend a bunch of money on parts that might not fix the issue.
How about you take the same fingers you typed this with and shove them up your ass far enough to where you can bite your nails
Its the transmission slipping
Its the muffler bearings
Blinker fluid is low
U-joins are shot
Brake light is out
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
i had the same issue about 5 months ago, had a bad solenoid (2-3 shift got replaced and wasn't the issue) in trans, then the transmission pump blew up on me, check your trans fluid, it sounds odd but it is an issue from time to time with gm vehicles, i have a jimmy and you have the exact same type of transmission i do. just my 2 cents, but it could really be well over 200 things that may not be pin pointed, and a scanner can false read it as i found, it gave me a shift solenoid  that i replaced but it was the entire valve body of the trans.
https://www.youtube.com/channel/UCWd1ShRnPbDG9ppgJKpumdA <---- show some love to my channel
Alpine MRH-F255 (old school), sub channel not used
Skar audio VX35-ST tweets in front  (invest in them they are worth it)
kicker zr120- nice underrated amp
Powerbass s1204 subwoofer in a 1.75 custom slot ported enclosure tuned to 30hz
Front doors Prv 6mb200s 8ohm
Alpine type-e 5.25 in dash took a shave and a hair cut.....- not in use
Rear doors alpine 6.5's model/series unknown but they are loud as hell
Factory alt
3.5 farad cap, does the job for now.
Deck is a pioneer mixtrax 700bt model
And my baby my Pioneer EQ-6500 i got for 10.00
Back-up amps- Ma Audio 598i, kicker zr120, my highly under rated JBL LC-A502 1xx watt amp...
On the side- Quantum tweets not yet installed
 U gotta get codes , your probably gonna get a P1515 or P1516 witch is TAC module . Check your engine ground that goes to the throttle body and disconnect the throttle body connector look to see if the connector has green and corroded terminals . If all looks good I would replace the throttle body but only if u have those codes. That is a very common issue for no power on accl. The internals wear out .
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
Need to updated the ECU
Exhaust manifold bolt is broken
O2 sensor heater is bad
Axle bearing is bad
Lifters are bad
Have you got the codes yet?? NO?...
Ill keep sugguesting
Had the same issue. Presented the same problems you're describing. I was also low on my headlight fluid. Might as well replace them both.
  • Who's Online   0 Members, 0 Anonymous, 4486 Guests (See full list)
