2 hours ago, Keith77 said:
Need to updated the ECU
Exhaust manifold bolt is broken
O2 sensor heater is bad
Axle bearing is bad
Lifters are bad
Have you got the codes yet?? NO?...
Ill keep sugguesting
is your fingernails brown yet
You got a parts store that has loaner tools? Go in your second car, rent an OBD2 scanner, find out what the problem is and fix it. Then you ain't gotta stress it shittin out on you on the drive to the store.
guessing exhaust manifolds leak common issue
possibly the fuel pressure regulator is shot
tps sensor
O2 sensors
fuel pump
engine has a miss (check spark plug wires noticed a lot at the express bay that a lot of them work their way off)
lower intake manifold also a common issue among all gms
could be a bad spark plug
literally i understand where keith is coming from cause i could list more
fuel filter
clogged/old injectors
map sensor not working correctly
dirty MAF
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
7 hours ago, Ahmed Johnson said:
I never thought of that. I guess I can roll up and go to autozone real quick. The one by me is 24 hours
24 hour AutoZone? That's cool.
Pioneer 80PRS
tps sensor
O2 sensors
fuel pump
fuel filter
dirty MAF
I can see where he coming from but not you. Maybe if you read a little more you wouldn't have wasted your time typing this. Or you could do as I told him then maybe you can find something better to do
does it crank right a way or does it sit there and turn over a few times before it even thinks of firing
i think the wording has me confuse
i have no clue the condition of the vehicle there for i threw out ideas
i am sorry i have been a dick this month
if i had a guess at this point fuel pressure regulator
skar sk2500.1
alpine HU
2 x-15 sundowns
  • Who's Online   0 Members, 0 Anonymous, 4094 Guests (See full list)
