DEE151 Posted March 7, 2017 Report Posted March 7, 2017 i have a 10" sq HDS3, and not sure what box would be better for my sub, can you guys help me, and yes i will be having a sweet system put in. here are the 2 boxes i am looking at on ebay, please help 1 http://www.ebay.com/itm/231482662923?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT 2 http://www.ebay.com/itm/291983912064?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Chrysler 200 Limited, 2.4L I-4 Cyl 9 Speed Automatic, Granite Crystal Metallic. Built 6/15 MODBlue Led Interior Lights20% Tint WindowsHRK HID KIT 6000K
Joe X Posted March 7, 2017 Report Posted March 7, 2017 The first one is specless other than internal volume, the second one is tuned too high and the port area and area ratio look bad and net volume will be pretty low for that sub once it's in, I wouldn't recommend either but the second one seems worse.
reedal Posted March 8, 2017 Report Posted March 8, 2017 If you're willing to build your own with a good design, there's a few members on here that's will offer you a good design for nothing at all. Just post up your maximum dimensions to fit the enclosure in, what amp will you be using, what car it is, and what type of music you listen to. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
DEE151 Posted March 8, 2017 Author Report Posted March 8, 2017 don't know how to build. can you guys help? links, recommended sub box something? these forums are for help. and to learn that's why i'm here. so i need a box for my sub.. help would be much nice, can you guys post some links? Chrysler 200 Limited, 2.4L I-4 Cyl 9 Speed Automatic, Granite Crystal Metallic. Built 6/15 MODBlue Led Interior Lights20% Tint WindowsHRK HID KIT 6000K
DEE151 Posted March 8, 2017 Author Report Posted March 8, 2017 1 hour ago, reedal said: If you're willing to build your own with a good design, there's a few members on here that's will offer you a good design for nothing at all. Just post up your maximum dimensions to fit the enclosure in, what amp will you be using, what car it is, and what type of music you listen to. the car in my sig. system will be. 1 10'' sub hds3 sq1200 amp 3.5'' skar tweeters 4 6x9 jbl gto coaxial AudioControl lc2i rap music. Chrysler 200 Limited, 2.4L I-4 Cyl 9 Speed Automatic, Granite Crystal Metallic. Built 6/15 MODBlue Led Interior Lights20% Tint WindowsHRK HID KIT 6000K
06RTCharger Posted March 8, 2017 Report Posted March 8, 2017 Post ur dimensions of the available space. Take a measuring tape and measure the space you can use in your trunk. The height, width (left to right), and depth(front to back).
SkarredSierra Posted March 8, 2017 Report Posted March 8, 2017 The mod audiofanaticz makes boxes. You could pm him and ask.
Joe X Posted March 8, 2017 Report Posted March 8, 2017 7 hours ago, DEE151 said: don't know how to build. can you guys help? links, recommended sub box something? these forums are for help. and to learn that's why i'm here. so i need a box for my sub.. help would be much nice, can you guys post some links? So here is a suggestion, sub /port firing back, you will need to verify the provided dimensions will work with your vehicle, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Suggested materials to build the above: 1) 3/4" MDF wood. 2) Titebond II wood glue. 3) MDF/Drywall screws.
ckeeler11 Posted March 8, 2017 Report Posted March 8, 2017 15 hours ago, DEE151 said: the car in my sig. system will be. 1 10'' sub hds3 sq1200 amp 3.5'' skar tweeters 4 6x9 jbl gto coaxial AudioControl lc2i rap music. My ears are bleeding just thinking of all the highs.
1gggman1 Posted March 8, 2017 Report Posted March 8, 2017 Try this site... the manufacturer directs all queries to Atrend automatically.... Hope this helps! https://www.atrendusa.com/soundqubed-10-soundqubed-single-vented-spl ...
