ramon.in.da.615 Posted March 20, 2017 Report Share Posted March 20, 2017 I'm looking to install 2 xs power super bank batteries that will be run parallel to a alphard audio Deaf Bonce DB-12000.1D mono block amp. I am curious if I run a second alternator at 370amp will keep the 2 xs power batteries charged.. Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 20, 2017 Report Share Posted March 20, 2017 The XS Power Super banks are not batteries, they are banks of capacitors inside a traditional sized battery case. As for will the alternator keep them charged, its hard to say, and would ultimately come down to how long you play it full tilt, and what model super banks because they have different sized models that are rated differently from each other. Link to comment Share on other sites More sharing options...
ramon.in.da.615 Posted March 20, 2017 Author Report Share Posted March 20, 2017 What would be the best batteries to use. I'm looking to run the 2 batteries in series to produce 24v, since the amp will produce 15k at 18v Link to comment Share on other sites More sharing options...
RooTxBeeR Posted March 20, 2017 Report Share Posted March 20, 2017 5 minutes ago, ramon.in.da.615 said: What would be the best batteries to use. I'm looking to run the 2 batteries in series to produce 24v, since the amp will produce 15k at 18v What amp are you going to be running? You sure it is stable to run that high of a input voltage? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Kyblack76 Posted March 20, 2017 Report Share Posted March 20, 2017 what the fuck..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
deathcards Posted March 20, 2017 Report Share Posted March 20, 2017 9v-18v pretty sure 24v will make it protect http://alphard.audio/general/amplifiers/deafbonce-db-12000-1d skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 21, 2017 Report Share Posted March 21, 2017 This is the only 24v amp I know of. http://www.ebay.com/itm/PYLE-PLTA180-2-Channel-800-Watt-24-Volt-Truck-Bus-RV-Bridgeable-Mosfet-Amplifier-/161983235626?hash=item25b6f4062a:g:LxAAAOSwPCVX6pmg 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ramon.in.da.615 Posted March 21, 2017 Author Report Share Posted March 21, 2017 alphard audio Deaf Bonce DB-12000.1D The amp requires 18v to make 15,000 watts rms. What should I use to produce 18v Link to comment Share on other sites More sharing options...
mrd6 Posted March 21, 2017 Report Share Posted March 21, 2017 A 16v system that will charge at 18ish. You are not ready to do this. I would sugggest choosing an appropriate amp to get the power you want at 12 volts My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
ramon.in.da.615 Posted March 21, 2017 Author Report Share Posted March 21, 2017 Im not ready to do this? Link to comment Share on other sites More sharing options...
