General wiring practices
Well I just got done ripping the old ass alarm/remote start out of my car, and now I have the fun task of fixing all of the chopped up wiring.  I have always been a solder and shrink tube guy, but I have seen that its not really the best practice in a car.  This car will be a high HP street driven/track car, so reliable wiring is a must.  Just curious what method I should use to put this all back together.  They seemed to mostly window the stock wiring, and just wrap the wire around it.  No solder, just some electrical tape on top.  Some of them are kinda close to the connectors too, so whatever I do should be really fun :)  I wonder how hard some of these pins would be to find....  Anyway, kind of a random question but lets hear what you guys think.
Sean
Idk but dont use typical electrical tape, that shit is a mess and starts to unwind after a while and leaves everything sticky. Use tesa tapes. For wire ends ur not going to use just fold a half inch of the end over and slip a peice of adhesive-lined heatshrink on it. So the bare wire end is within the middle of the Shrink tube. Bundle all those unused end together and tesa tape it.
As for connecting wire to wire techniques....ill leave that issue alone lol
Sean
use ring terminals/lugs on wire ends and put an appropriately sized bolt through both eyelets to connect.
If you're splicing into existing wiring:
Strip back 1/2" or so of insulation
Wrap the wire around the existing wire
Solder
Tape with Super 33+
I've been doing that for 30 years now without one single failure.  My books show all of the correct methods and good practices - https://ceautoelectricsupply.com/wiring-and-efi-conversion-books/
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
duct tape.
J/K What Snafu said ...
Solder
Tape with Super 33+
The only person you absolutely have to listen to is this man right here. Also, buy that book. If you have questions like that its your new bible.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
OK, I may need to clarify a bit here.  I am removing (and not replacing) and existing alarm wiring.  So they have already windowed factory wiring, and also cut factory wiring.  I am mostly trying to figure the best method for connecting two straight pieces of wire end to end.
Thank you,
Sean
Dang. What type of car are we working with here ???
1993 Lexus SC400.  Alarm was a Viper V60 that was installed in 97 I believe.  It never worked since I got the car, and the other day I had to charge the battery since it died from sitting and it started going off.  That is when I found out it had three horns!  It also had 4 under dash switches, one of which finally allowed me to start the car after pressing it twice with the key on.  Yeah, the alarm had to go :)
Sean
  • Who's Online   0 Members, 0 Anonymous, 954 Guests (See full list)
