Running 5K? What's your electrical like?
1 minute ago, 8ten8 said:
Good lord...from 8 to 1. Thats one hell of a ratio. Lol
Yeah but those batteries are tiny.
Honestly, wish I spent that money on an alt. Personally I suggest thats the first thing you budget for.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
Second Skin
^^^ Build ^^^
Copy that. I'm in the process of purchasing a US alt. My choices are so far: 170 hot@ idle-220 hot@ 2000rpm or 120 hot@ idle-240 hot@ 2000rpm. I don't do alot of freeway driving.  What's your thoughts?
I'd buy the 220. +50 more amps @ idle would be for me. My car is stick and I drive like a grandma so Im in low rpms 99% of the time.
Aren't US alts underrated? or is that someone else?
I've never had any HO alt other than excessive so I don't have experience with any other company.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
Second Skin
^^^ Build ^^^
More idle amps. 120A at idle isnt much. Especially if you are stop-and-go a lot or enjoy demoing
IG @walledsonic
3 hours ago, 8ten8 said:
Yeah, Tony D. I saw the same vid a while back. The test proved positive. Long runs not needed.
He also only used an amp that drew about 175A (his words). Im curious as to how results vary with a "large" draw.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
On a unibody car you will want one ground run per positive run after the first two positive runs. This is with grounding to the chassis. Full frame can do more positive runs before negative runs are needed. The only way to truly know how many runs you need is to keep adding runs until no improvement is found. Then add one more.
Pioneer 80PRS
Ok. So far, under the hood, I've got 2 grounds from chassis to front batt, 2 grounds from block to front  batt, 2 grounds from block to chassis and 2 power runs from front batt to rear. Nothing in the rear yet. Thoughts?
It's a 02 Subaru outback
I wonder if electrical noise could be a concern with amps going to chassis ground.
IG @walledsonic
What would be an alternative to grounding amp to chassis?
Directly back to battery ground.  Battery ground is the truest ground.  Its the voltage source.
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 3996 Guests (See full list)
