Amp goes into protect when i hit the gas
I have been riding around today and noticed the amp will go into protect when i give the truck some gas from a stop.  I have a missing link audio voltage module in and the output is in the low 15s.  When i give it throttle from a stop only one of my amps go into protect for a split second.  Whats the deal how do i fix this.  I have one of meades voltmeters measuring it so i think it must be the high voltage spike.  System has a 270 amp alt and 300 amp alt, 3 group 31 batteries, 6 runs of 2/0 positive and negative, a t1000.4ad, a p400x4, and a t40001bd.
Does it still protect if you turn down the voltage?
Whats the specific model of your MLA? it should have some adjustment on it. More than likely, your voltage spike upon acceleration is higher than the amp can handle, causing over-voltage protect, and then when your voltage notmalizes, its fine.
Unplug the alternator and try again. I bet you it'll do the same thing if you were to rev the vehicle in neutral
Sounds like when you rev you are getting higher voltage which is making the amp protect.
  • Who's Online   2 Members, 0 Anonymous, 1390 Guests (See full list)
