Port Area
I'm trying to make a decision on port area (not port area per foot)    from my understandings they are 2 totally different thing maybe I'm wrong.  I have a psi platform 5 12 and it doent have a recommended value for port area.  So is there a general number for 12s or does it even matter?
So does port area matter. For example I use an app called box tune calculator and it gives this as a specification for when you put in information. Is it a critical number? If I'm to low will it alow me to lose controls of the cone or maybe in the other direction. To much cone control?
Yes it matters.  You need to keep port velocity down.
Try this:
After you determine port area, determine port length to get the tuning.
IG @walledsonic
1 hour ago, alex912005 said:
The only rule is that you're supposed to have between 12 and 16 square inches of port area per cubic foot of box volume. For example, Digital Designs recommends the max 16 square inches for their subs.
that is a rule of thumb, not a rule as in law. You can easily create a great box outside of that range. All depends on cone area, xmax, and power applied.
This is correct. If someone gives you that 12-16 shit, they mean well, but they are likely not much more experienced than you are. There are many experienced enclosure builders here that can help you, wait for them to chime in.
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
What power will you be putting to it, what will it be tuned to and what is the net volume (volume after displacement of sub, port, bracing etc.) of the  enclosure?
  • Who's Online   0 Members, 0 Anonymous, 2056 Guests (See full list)
