5000-8000 watts rms electrical
Any advice/recommendations are appreciated.
Planning out a new system build for my 2001 Ford Escape. The new system will include two soundqubed 18's (HDC3s or HDC4s if I can find them for the right price) in a 12 cube ported box. For amps I'm either going to strap two CAB 1600s or just get a taramps 8K. My question is whether one XS Power d3400 will be enough (along with a d1200) or should I go for the d3100. I have a stock alternator (110 amps) without the big 3 upgrade with 0 gauge welding cable from front to back.
Current system has a kicker KX 2400.1 (2600 watts rms) with a XS Power d1200.
Needs much more electrical
IG @walledsonic
tbh i couldn't agree more with this
try a good brand h.o. alt
2-3 batteries in back with upgrade battery underhood
and always watch voltage with that much power
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
I ran a 6K with a 240A singer alt and 395Ah of XS battery and I couldnt play full tilt at idle more than about 20seconds without needing to increase the RPMs. And I had rise that started at 1.3ohm.
IG @walledsonic
Voltage with my current setup rarely drops below 12 volt with everything turned up. I know that will change when i double or triple the power output. I'm trying to stay away from a H/O alternator and won't using the max potential of the amps I have. Plan on making a big system to use for a few months before I move off to college, afterwards everything will be removed.
3 minutes ago, Jake Pace said:
OK get these caps in the video as well that Steve himself uses and you know damn well he is pushing alot of power!
LOL have you checked the cost of caps?
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 308 Guests (See full list)
