bcbrassard Posted February 5, 2018 Report Posted February 5, 2018 1 hour ago, 8ten8 said: Mid bass FTW imo ( and a little sizzle). What are the 6.5's & 8's crossed over at? 6.5" 100 hz and up 8" 120 hz down to 65 hz
WalledSonic Posted February 5, 2018 Report Posted February 5, 2018 I used expanding foam and PL glue in the cracks and crevices inside my door panel. PL doesnt bond to plastic that well, though. EDIT: doors look great man, good job Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
bcbrassard Posted February 5, 2018 Report Posted February 5, 2018 5 hours ago, WalledSonic said: I used expanding foam and PL glue in the cracks and crevices inside my door panel. PL doesnt bond to plastic that well, though. EDIT: doors look great man, good job I used hot glue everywhere on the panel to try seal it up and make it stronger before and modify. Thanks for chiming to give examples of how you did it.
WalledSonic Posted February 5, 2018 Report Posted February 5, 2018 Did the hot glue stick well? Curious, because even though the PL helped fill voids and definitely decreased rattles, it didnt adhere to the surfaces well so I would use something different in the future. The expanding foam worked great though. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
bcbrassard Posted February 5, 2018 Report Posted February 5, 2018 53 minutes ago, WalledSonic said: Did the hot glue stick well? Curious, because even though the PL helped fill voids and definitely decreased rattles, it didnt adhere to the surfaces well so I would use something different in the future. The expanding foam worked great though. Yes the hot glue sticks well IMO. I hope the expanding foam will add the strength to take the flex and rattle away.
sTp Posted February 5, 2018 Author Report Posted February 5, 2018 Yeah i used the hot glue everything on my pod's i made this weekend they seem pretty sturdy at the moment i will post a photo up tomorrow to show you what i have done so far and to show you where i was on about the part's to foam.
WalledSonic Posted February 6, 2018 Report Posted February 6, 2018 I want to try E-6000 on some spots in my car. That stuff forms a flexible bond to plastic really well. Used it for so many things around the house. My car's front grill is laser cut from a guy on a Sonic forum and E-6000 literally holds the whole thing together. Had it installed for 18months and no sign of failure in sight. Full weather, texas 110deg heat, road crud, etc. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
sTp Posted February 6, 2018 Author Report Posted February 6, 2018 Here you go guys https://imgur.com/a/TYiHQ wouldn't let me add the image as was to big but thinking about using foam around the void and the red parts after the resin has been set. will be 1 8'' rockford punch pro and 2 T3 6.5 running off a T-800-4
bcbrassard Posted February 6, 2018 Report Posted February 6, 2018 Map pocket area would be good IMO. the other area i don't know, I would think using filler to make that solid would be better. Like i said, after i finished layering the fiber glass i used Kitty Hair Bondo to help reinforce those kind of spots. Looks like you have a solid lay out on the doors, should turn out killer when your done.
audiofanaticz Posted February 7, 2018 Report Posted February 7, 2018 There is no real need that I see. Once you wrap the pods in fleece and soak it in resin, the resin will soak into the rings as well making a very strong bond as 1 entire piece. Then you can go over the interior of the pod with fiberglass cloth/chopmat if your still concerned, and do a layer of kitty hair on the exterior to smooth out any blemishes before filling any smaller imperfections in with bondo.
