I’m buying 4 2ohm subs yet I’m putting them in two separate boxes I’m going to wire it down to 1 ohm but the problem is how would I do it since there’s two separate boxes?
Wire the coils of the subs in series, then each sub is 4 ohms.  Wire the subs in each box together in parallel, then wire the two boxes together in parallel.  That will get you a 1 ohm load to the amp.
Builds:
