Made my own SMD VM-1 (for educational purpose)
Hi everyone. Let me start by saying I am in no way trying to steal damore's design or anything, it was just a fun project for me over winter break. I have always wanted one of their meters but, being a college student it was always a bit too much to spend on a voltmeter. Yes, I know it is a very good voltmeter, but one that is slower does the same thing, but it is just so cool.
Anyway, I made my own version of them. Not being able to find any documentation asides from what was provided on damore's website, I went to designing it. I decided on the Atmega328p microcontroller. I believe the SMD one uses something similar, but I'm not sure as I've never seen one in person (well I have but not the circuit side of it). All in all, it took about 2 weeks from start to finish until I got it working the way I wanted. I also made a temperature one as well ?. One main difference on mine vs. the SMD is that the SMD one has a response time from one end to the other of 130ms, whereas mine is 180ms (but I can make it match).
Pics/vids: <link removed>
I will for sure be buying the actual SMD meters when I can :)
Very cool
IG @walledsonic
17 hours ago, bsneon98 said:
very cool. Where did you get the board?
thanks everyone. i designed the board and had the pcb made.
Damn thats pretty badass. Does urs go counter clockwise? When u start ur car looks like it goes clockwise because the red lights are at the far right. Should try next to make some like the vu-din ones(i think thats the name). Those just had more of a line of lights so it kinna looks like a RPM needle bouncing back and forth around the meter. Found a pic.
Would be cool to have the smd single meters with this style of lights, the gauge cluster meter similarity just looks good. But the regular smd ones look dooe too, reason i bought i couple and plan on getting a couple more.
awesome. Did you use eagle by autodesk? I have some playing around in that to do. And what service made your board? Ive been looking for a good source.
I did not, I used easyeda which is a website based pcb designer. It's pretty good for what it is. I use elecrow for my PCBs. They usually throw in a couple extra boards for free and quality has always been good ?
They go clockwise, the one with the red leds on the right is the temperature meter ?. I actually have the circuit for the VU one made, but I want to build a test circuit to see if it works as expected before I order the pcb.
