The birth sheet says 540RMS
RF claims 75 x4 @ 4 ohms
100x4@ 2 ohms
200x2 @ 2 ohms bridged
since the birth sheet is 540rms does this mean its outputting
110x4 @ 4 ohms
135x4@ 2 ohms
270x2 @ 2 ohms bridged
Those are most likely your RMS figures at 14.4V. What you can reliable count on, with a good working alternator and electrical connections. Dynamic burst will be higher.
i understand that, but like what would my rms x4 @ 4 ohms be? how can you calculate that? factory the max would be 400rms, but it birthed at 540rms. SO i'm assuming 540-400=140/4 = 35+75(rms x4)=110rms
To many variables, i think your over thinking it.
16 hours ago, MrSkippyJ said:
Just assume it does rated and use that value.
I'm just curious if it can be easily calculated. The older rf amps told you what rms they did at each ohms. I guess the new amps only give you the total rms on the birth sheet
You can't accurately calculate it, it has to be measured. You can guess just like you have been, but without measuring anything you come up with is a guess.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
