White Lightning Posted April 16, 2018 Report Posted April 16, 2018 13 minutes ago, robsimon799 said: im looking for both SQ and SPL but not at the same time just the same truck, its not hard to do ive been in this game i was 9 years old and now im 36 instead of processors, you need to be focusing on "adequate to your application" head units first. Every piece of equipment is only as good as it's application. ... And every vehicle is a different application. There is simply no End All Be All piece of equipment to fit every application. Trust me, It's been tried. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
robsimon799 Posted April 16, 2018 Author Report Posted April 16, 2018 im useing a 2000 f150 supercab and flareside bed with the subs in bed firing though a cut though to the cab 4 18s 2 35000 rms bass amps and 6 way mids and highs in the back of the cab and doors http://store.crescendoaudio.com/pwx-10-midrange-speaker/ and there horns and super tweeters and amps with independient channels or each speaker. for sq i will turn off the 4 18s subs and have 8" morels in back of cab and in doors and dash with 2 4ch hcca amps. dash speakers. and e3io car pc with 7 gen mouther boead and pross. i disply with 2k i pads
CstrokerV Posted April 16, 2018 Report Posted April 16, 2018 you might want to reconsider your front end if you are looking for it to be sq based.. just my opinion though my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 1 hour ago, CstrokerV said: you might want to reconsider your front end if you are looking for it to be sq based.. just my opinion though what would you like to change?
CstrokerV Posted April 17, 2018 Report Posted April 17, 2018 Talk to white lightning he’s sq guy my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 2 minutes ago, CstrokerV said: Talk to white lightning he’s sq guy like for in sq i can turn the front end center channel
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 The fuel system the be a 2 stage 91 OCT main injector to sec. injectors with 100% methanol with 16 injectors total Engine MMR 400 CU GEN X ,10:1 comp, Turbo cam, DOHC V8 Engine Nelson Racing 72mm Twin Turbos Custom dual inlet single out air to air intercooler with fans Intercooler piping Oil cooler with fan Oil catch can with air filters Coolant res Top mount turbo manifolds Electric water pump AN fittings on rad and engine and everything under the hood Electric rad fan and electric water pump Frame IFS IRS AWD box frame Custom control arms for rear Custom A arms for front Custom knuckles Rack and pinion steering Suspension Airlift slammer shocks bags or Airlift bags and JRZ shocks 2 Airlift air comp. 480c airlift p/h controller 1 ton ball joints Spidertrax hubs 5/8"-18 studs on a 6 on 5-1/2" bolt circle and 40 splined axle shafts front and rear 2 Wilwood Brake Kits No: 140-8992-D for front and rear Savini XLT SV25-S Wheels: Custom chrome same from front to rear 26 x 10 or 26 x 12.5 or 26 X the widest max pirelli P Zero all session Drivetrain TCI 6 speed transmission and outlaw shifter SCS transfer case RCV custom CV Axles front and rear Two Currie F9 9” diff housings, flanges, bearing and seals Two Nitro drop outs Two Auburn Gear ECTED MAX diffs OR front and rear 8.8” ford Sport Trac Andrenan AWD diffs housings with ected max diffs Fuel 2 Radium fuel cells and surge tanks -10 black braded fuel feed hose Exhaust 2 HKS ti burn tip mufflers 75mm inlet 3” exhaust pipe two 3” vibrant cats v band 3” Lights IPCW LED black housing Tail Lights Spec-D® - Black/Smoke Dual Halo Projector LED Headlights modified housings XK Glow smart phone controlled under lighting and interior lighting 2 round grill lights 7” dia. Body Sarona front clip FD-010-FB Sarona side surts FD-006-SS Sarona rear clip FD-007-RB Sarona front fenders FD-004-FD Sarona air ram hood FD-006-HD ARE LS2 Tonneau Cover BMW flossmann gt2/3 rear spoiler with red led brake light Ford f150 sun roof Mesh matt black grill Black Truck with Blue accents Audio E3iO Computers fully loaded car pc E3iO 10” screen Alpine pxa-h800 Alpine rux-c800 Custom Switchable stereo to stereo/mono units 7 channels 2 Crescendo C2000.4 amps 5 Crescendo SYMPHONY S550/2 3 crescendo s800/4 2 Orion HCCA 3000.4 for the 2ohm 8” subwoofers in kicks and back of cab made out of MDF and fiberglass 2 Ground Zero 35000 Watt RMS Amps low pass 80HZ for 18” subs 4 Crescendo PWX 10" Pro audio 500rms 4 ohm 8 PWX 6.5" Pro Audio 250rms 4 ohm 4 PWX 8" Pro Audio 300rms 4 ohm 7 Crescendo FT1 Super tweeters 80rms 7 UN-1 ULTRA NEO COMPACT COMPRESSION HORN 7 Morel ULTIMO TITANIUM 8” 2 ohm Subwoofers 4 Ground Zero SPL Extreme 18” subwoofers audio pipe crossovers Wiring and electrical Push button start with switches for ign. ACC. Fuel pumps aux lighting and FAST XFI 2.0 FAST XFI EDASH M&W PRO DRAG 8 CDI Weapon X XCOP EFX Direct Fire Ignition Coil Add on fuse box for lighting 8 gauge input Mechman E Series 6 phase 370 amp alternator for 5.0 Coyote 8 XS Power lithium batteries XS30K sky high car audio OFC 2/0 gauge blue power and ground cable sky high car audio OFC 4 gauge blue power and ground cable sky high car audio blue OFC speaker wire 16awg for 6 ½ mids and tweeter horns / 14awg for the 10” mids and 8” mids/ 10awg for the 8” subs / 8awg for the 18” subs. 9 SKY HIGH CAR AUDIO 2/0 ANL FUSE HOLDER - SET SCREW. 4 sets SKY HIGH CAR AUDIO DUAL 2/0 TO 1/0 AMP INPUTS GZ 35000.1 amp 2 sets SKY HIGH CAR AUDIO 2/0 TO 1/0 Amp inputs for HCCA 3000.4 amp. Interior Corbeau black leather Heated CR1 seats blue face gauges for dash cluster blue led for gauges and dash and window power switches clear gauge needles Phantom 2 BOOST/VACUUM, 30 IN HG/45 PSI gauge And all other autometer phantom 2 gauges we need on 3 pod a piller and dash. Custom mdf and carbon fiber Center console 18” subs sub box ported @ 20HZ sub box in bed of truck with bed front cut out and back of cab cut out.
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 thats what I'm building for a truck. but i emailed alpine and they concetiring my plan for DSP
White Lightning Posted April 17, 2018 Report Posted April 17, 2018 1 minute ago, robsimon799 said: thats what I'm building for a truck. but i emailed alpine and they concetiring my plan for DSP Not to be rude in any way, but I can clearly understand why. Your equipment list match none of your goals you’ve posted so far. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
robsimon799 Posted April 17, 2018 Author Report Posted April 17, 2018 5 minutes ago, White Lightning said: Not to be rude in any way, but I can clearly understand why. Your equipment list match none of your goals you’ve posted so far. I'm asking how so? I'm want sq and spa at diffriont times. sorry for the spelling.
