How to attach these speaker pods?
Sup guys, I am thinking about cutting a thin 1/2" sheet of MDF and attaching it to the bottom of my door panel and then screwing these plastic speaker pods onto the doors. Thoughts on this?
sparkgeorg-ebay-fiberglass-pods-trimming
My old eBay fiberglassed Pods looked like this but it was too bulky so I"m redoing it with new smaller pods.
sparkgeorg-ebay-fiberglass-ghetto-box-7.
sparkgeorg-ebay-fiberglass-pods-done-10.
Do it. Next time tho, consider a jigsaw to carefully cut the plastic door panel.
IG @walledsonic
Yeah, I bought a dremel after I had already f*cked up my door panels with the box cutter :(
My dremel couldnt get a clean cut on the plastic door panel. It would heat up too much and leave the edges of the cut with bunch of globs of melted plastic. I mightve been using the "metal" cutting discs tho, maybe another bit would make cleaner cuts.
But damn, u took a box cutter to the doors? Lol gangsta.
Even with the plastic and thin cuts I still get some build up on the edges. I think jigsaws your best bet but maybe one with a lot of teeth and take your time.
Huh. When I use a dremel on plastic... For the most part, I actually run the tool high RPM to melt the plastic. Feel like it's easier to do what I want that way once you get the hang of it down. Just de-burr the blobs at the end and everything comes out clean. Easiest way is just a sanding drum at low RPM, breaks the re-hardened melt right off
Jigsaw is clean as fuck with plexiglass blade. I cut mine flawless. No burr, no melt. Ill post a pic from my BL later
EDIT:
26767212487_639875bdb9_k.jpgIMG_5628 by Walled Sonic, on Flickr
IG @walledsonic
Actually looks decent. I forgot to take pictures of the 1/2" thick plywood under the pod before adding carpet.
Used a Dremel tool to cut a hole in the door panel for a nice flush trim tweeter install. I made a mistake spray panting the nut ends on the pod and f*cked up the paint on the pods :( Also the carpet on the right wasn't done right so I had to cut another piece to lay on top.
Looks cleaner than what I had going on before (two of my crossovers are inside of the door behind the door panel right now.
sparkgeorg-ebay-fiberglass-pods-done-5.j
Sounds better than the old eBay pods I had. Subs turned off in this video.
  • Who's Online   0 Members, 0 Anonymous, 1839 Guests (See full list)
