BRiedman Posted August 3, 2018 Report Posted August 3, 2018 So I have 4 Orion HCCA 12.2 powered by an Orion HCCA 8000.1d So I have 8 gauge and 14 gauge (sky high car audio) wire already, am able to buy more/different size if needed. I was planning on using the 14gauge wire because the terminals on the woofers are quite small. I was curious What would be the best wire gauge to use for them though?
k58.cross Posted September 11, 2018 Report Posted September 11, 2018 Are they wired at 1 ohm each woofer? If so.... 2kW for each woofer at 1 ohm per means about 44.7 Vrms on the woofer at your 2kW. 2 kW/44.7 Vrms = 44.7 Arms (thanks to 1 ohm operation). American wire gauge chart says you can use 10 gauge in the 35-50 A range for lengths anywhere from 0-10ft.
k58.cross Posted September 11, 2018 Report Posted September 11, 2018 Note - this is why speaker wire is so much thinner on average than power wire, because the speakers have a much higher voltage across them.
MrSkippyJ Posted September 11, 2018 Report Posted September 11, 2018 I thought current was related to wire size and voltage was related to the insulation capabilities. --this might be semantics though...we might be saying the same thing. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
k58.cross Posted September 12, 2018 Report Posted September 12, 2018 Yeah that is correct. I should have worded it differently - Since you're setting the power to a specific level and running a high voltage (as compared to the input of the amp), you're drawing a smaller amount of current. That's what allows the smaller wire size.
BassMunky Posted September 12, 2018 Report Posted September 12, 2018 good to know Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
