DiBo Posted April 8, 2019 Report Posted April 8, 2019 Anybody with any knowledge on Maxwell boost Caps or XS power super caps? I would like to hear it from the horse's mouth. Are these worth the cost and are they worth using? I can get banks for $200 used with basic hardware. Any help would be awesome. Thank you
realflow100 Posted April 8, 2019 Report Posted April 8, 2019 I'd spend the money on upgrading the wiring and alternators and battery instead but thats just me. caps only really do anything if your doing huge burps of power for short periods of time like one or two seconds otherwise they are just not doing much of anything.
DiBo Posted April 8, 2019 Author Report Posted April 8, 2019 19 minutes ago, realflow100 said: I'd spend the money on upgrading the wiring and alternators and battery instead but thats just me. caps only really do anything if your doing huge burps of power for short periods of time like one or two seconds otherwise they are just not doing much of anything. I have 2/0ga throughout. 100% ofc. A singer 320 and a Mechman 320 alternator also. 640amps total alternator power and switching to Lithium soon. LTO cells. Just wanna do everything and anything I can to make my electrical as stout as possible. I'll be trying to clamp around 12k at least. I want long demos at idle if need be.
SnowDrifter Posted April 8, 2019 Report Posted April 8, 2019 I think supercaps are a great tool to buffer between alternator charge voltage and battery voltage. Just DO NOT FORGET TO BALANCE THEM!!!! Shoot me a PM if you need help with that or need clarification on what it does / why you need to do it. And then this for how it behaves on music. This was prior to the nice SMD VM-1 so it's just on a corny digital display. Relevant time stamps are 0:25 and 3:00 without and with an 850 farad bank installed, respectively ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Skullz Posted April 8, 2019 Report Posted April 8, 2019 Just save your money now if you plan on jumping to lithium. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
DiBo Posted April 8, 2019 Author Report Posted April 8, 2019 3 hours ago, SnowDrifter said: I think supercaps are a great tool to buffer between alternator charge voltage and battery voltage. Just DO NOT FORGET TO BALANCE THEM!!!! Shoot me a PM if you need help with that or need clarification on what it does / why you need to do it. And then this for how it behaves on music. This was prior to the nice SMD VM-1 so it's just on a corny digital display. Relevant time stamps are 0:25 and 3:00 without and with an 850 farad bank installed, respectively How much power? Alternator, amps and batteries? Thank you for the videos. Significant difference with the caps.
SnowDrifter Posted April 8, 2019 Report Posted April 8, 2019 TBH I don't remember. This one was a while ago. It was after I went to 14v, but before lithium. Alternator would have been either a 270a or a 390a. Amp could have been a 3.5 or an 8k. I think it was a 3.5k and 270a but don't hold me to it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
DiBo Posted April 8, 2019 Author Report Posted April 8, 2019 6 hours ago, SnowDrifter said: TBH I don't remember. This one was a while ago. It was after I went to 14v, but before lithium. Alternator would have been either a 270a or a 390a. Amp could have been a 3.5 or an 8k. I think it was a 3.5k and 270a but don't hold me to it Now you're running strictly lithium? I think a big enough lithium bank might be enough.
kalilac619 Posted April 8, 2019 Report Posted April 8, 2019 I've done and ran every combo possible....Alt + agms....alt+agm+Lithium...alt+agm+lithium+caps...Alt+Agm+caps ...Alt+lithium+caps ...and Alt+caps ...Alt and caps gave me the best results .....current setup is 2 Singer 370 hairpins and 14 banks of maxwells....voltage drops only about .5 demoing 3-4 songs in...burps drops only .2 ....setup is 2 sundown NSv4 18s in a 6th order on 2 sundown SCV7500s at .5 each ......with good Alt and enough banks you'll be set 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
rocking.that.eclipse Posted April 8, 2019 Report Posted April 8, 2019 I ran 2 xs 40ks and 2 banks of their caps. A pair of 270 amp alts was able to keep up with 14k of rated power. Started at 17.1 and dropped down to 15.8 after a while. I think that the buffer between alts and batts with caps helps it drain down more steadily. Had a buddy with a very similar setup to mine and he would drop 17.8 to 15 flat with no caps. May or may not mean anything tho with the setup difference we had
