Ive been trying to come up with a way to fit a 15 cube enclosure in my non-ext trailblazer to go subs up/ port back. No matter what I try there just wont be enough room between the back of the enclosure and the liftgate........so can I go subs up port up and still knock?
if you can fit it sure. but whatever you do dont try and squeeze a 15 in there with too small of an enclosure. just step down to a 12 if you have to
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
15 cubes? how many 18's you trying to do in there? 3 or 4?
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
I had a sub-up-port-up setup and it sounded cleaner because there was less over-all rattle in my tail-gate. But, I will not bull shit you into thinking that it is louder than sub-up-port back.
The most important thing is how much room the air has AFTER it leaves the port. That is important. If having your port back is too tight of a fit, then maybe it's best to fire it up like I did.
Make the box smaller to allow for rear fire port. You dont need 15 cubes.
