Amp settings question?
escottl92
24 minutes ago, escottl92 said:
I have an Ampere 7500.1 mono amp, I am wondering what people are setting there subsonic level too? Or if your even using it. Also LPF should set too?
Thanks for help
Depends on you box and subs. List that info.
My box is tuned to 32hz SSF around 26
2 hours ago, escottl92 said:
How do I know what my slope is?
Usually says something in the manual of the amp. If not check out online
Nice subs, I almost got a team but went with the sp4 plus. As for your lpf that will depend on the slope too. Note that it may be different from the slope of your infrasonic filter. If it's 12db/oct then a good place to start would be between 60 and 65 hz and if it's 24db/oct then start at 80.
The settings are variable for a reason. What is good for me, may not be for you. Adjust to your liking, or to YOUR set up/gear.
Like the last post. My low pass started at 45-50. And fuck a high pass(subsonic). That is what I wanted to play.
  • Who's Online   1 Member, 0 Anonymous, 1484 Guests (See full list)
