SesameCreeps Posted January 8, 2020 Report Posted January 8, 2020 I never ran dual inputs before been looking into it. Might be a stupid question but when running 2 power wires from the battery and they meet into one dual input adapter, you still fuse both power wires up front correct?
bcbrassard Posted January 8, 2020 Report Posted January 8, 2020 55 minutes ago, SesameCreeps said: I never ran dual inputs before been looking into it. Might be a stupid question but when running 2 power wires from the battery and they meet into one dual input adapter, you still fuse both power wires up front correct? Power wires always get fused within 16" max from battery or battery's in a trunk or other location. The rule is usually the shorter the better.
SesameCreeps Posted January 8, 2020 Author Report Posted January 8, 2020 oh ya duh they would be running from the battery in the rear. thanx
Mike4068 Posted January 8, 2020 Report Posted January 8, 2020 Unless you are trying to gain a tenth of a db for competition dual inputs will only increase the cost of your build. Save your money for bigger and better equipment.
Joshdashef Posted January 9, 2020 Report Posted January 9, 2020 16 hours ago, Mike4068 said: Unless you are trying to gain a tenth of a db for competition dual inputs will only increase the cost of your build. Save your money for bigger and better equipment. I will say they look sweet as well. + 10 db to looks 😂 SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Kyblack76 Posted January 9, 2020 Report Posted January 9, 2020 I never fused the amp hot run. We did because we had to in the burban for competition rules. But, if your fusing, yes, anything hot needs one SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
