Need source for wire ga adapter
I need to find an adapter that will let me use 4ga wire in a 0ga hole. Sometimes terminals come with a brass sleeve that you can remove to fit 0ga. I'd like to find out where to buy them from. I don't know exactly what to search for. Everything I have looked for has come up trying to sell me a 0ga to 4ga reducer...I need the opposite.
At the least I'd like to know what the thing is called.
Thanks!
19 minutes ago, audiofanaticz said:
I dont think you can buy those, and the only time I ever seen them is in fuse holders like these https://www.sonicelectronix.com/item_45096_NVX-XMANL04.html
I dont know why one would want to use a smaller gauge wire than needed though, especially if something needs larger.
I was assuming he’s running an amp at 4 ohms and already has the 4 gauge ran.. who knows but him
Sorry for the late reply. I have some battery terminals that I can use on my 0ga wire but the two smaller holes are not large enough to accommodate the 4ga factory wire. I don't really want to cut the factory wire. But if I could have found a bushing/adapter that would allow it to happen, then maybe I would. I think what I'm going to do is send the ones I have purchased from amazon back and look around for a better solution. There is a set from Knuconcepts that I like and will probably get.
http://www.knukonceptz.com/mobile-audio/battery-terminals/sp/ultimate-positive-battery-terminal/
