Amp getting hot.
d-nice88
Want to see if I've made a mistake somewhere. Can some one help me out ? My skar 4 ch amp gets hot quick with in a few seconds of playing and goes into protect. I have a kenwood excelon deck with signal going from that to an audio control bass epicenter then from there to a clarion eq then finally to the amps in the back. I have some rigged up stuff going on with the way I have my speakers set up. I have a set of mid bass speakers hooked up to ch. 3 n 4. 1 n 2 I have hooked up to a set of components. Here's where the rigged up part comes into play. I also have a set of super tweeters hooked up in the passive cross over with the other tweets from the component set. On the cross over it has 0db + -3db+ and -6db+ Tw - then for the mid its W+ W- and input + -. I have the tweets hooked up to + -3db and Tw- and then the super tweets hooked up to + 0db and Tw-. That's how the passive cross over is wired up on ch. 1 n 2. Could that be my issue ? Is that making the impedance too low causing it to get hot? I haven't made an amp go into protect in a long time so I'm just trying to find out if that could be my issue or something else. Voltage is good going to the amp. Seeing 14 v when the car is on and 12.8 when the cars off. Any help is greatly appreciated.
plus you are changing the crossover points too. I would just disconnect the super tweets until you can install them correctly.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Got it hooked up like normal and still that Same thing. Plays for a few seconds once the volume gets to a certain point not even at the half way mark it cuts off and goes into protect. Idk what could be wrong. Polarity is right and everything
  • Who's Online   0 Members, 0 Anonymous, 4622 Guests (See full list)
