Fish Chris Posted February 11, 2020 Report Share Posted February 11, 2020 I searched high and low for something like a 90 degree elbow, that would clamp down on 1/0 power cable on both sides, but couldn't find anything ? How else would you put a sharp 90 degree bend in 1/0 cable ??? I need to come straight out of my amps, then drop straight down, with only a few inches of space to work with. Any ideas ? Link to comment Share on other sites More sharing options...
AaronT Posted February 11, 2020 Report Share Posted February 11, 2020 Go to home Depot, get ½" inside diameter PVC elbow and done thru will fittings that are threaded. Run wire into elbow Link to comment Share on other sites More sharing options...
Fish Chris Posted February 11, 2020 Author Report Share Posted February 11, 2020 Excellent idea TYSM ! Link to comment Share on other sites More sharing options...
AaronT Posted February 11, 2020 Report Share Posted February 11, 2020 I meant 90° slip elbow with thru Hull fitting glued to both ends You'll be able to screw it to amp racks to secure it Link to comment Share on other sites More sharing options...
Ron36 Posted February 11, 2020 Report Share Posted February 11, 2020 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
Fish Chris Posted February 11, 2020 Author Report Share Posted February 11, 2020 13 minutes ago, AaronT said: I meant 90° slip elbow with thru Hull fitting glued to both ends You'll be able to screw it to amp racks to secure it Oh okay, that might work even better. But even just a simple little PVC 90 degree elbow would help a ton Link to comment Share on other sites More sharing options...
AaronT Posted February 11, 2020 Report Share Posted February 11, 2020 Similar to this, you can trim the threaded part to fit clean with no excess think outside the box stop over in the electrical section browse over there conduit sometimes I just walk around hardware store looking at things I could be useful Link to comment Share on other sites More sharing options...
AaronT Posted February 11, 2020 Report Share Posted February 11, 2020 Oh I didn't see the inputs Ron36 posted That's a much much much better option than my idea and looks a whole helluva lot better. Link to comment Share on other sites More sharing options...
fishchris1 Posted February 11, 2020 Report Share Posted February 11, 2020 2 hours ago, Ron36 said: Hey Ron, TY, but for my purposes, those won't quite work... I mean, one would, but the other would need to come out just a little farther before it dropped down... So like I'd need it to be female on both sides and to clamp on both sides... If they make such a thing, I haven't seen it.... Link to comment Share on other sites More sharing options...
Ron36 Posted February 12, 2020 Report Share Posted February 12, 2020 What if you first used a normal reducer a then put the 90 in that. Might start looking crazy but depends on how far it has to go. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
