Leaked Photos Of G-14 Classfied Project
Now them specs look incredible! :D
Product Description:
* 10 Kilowatt Ultra-D Class Amplifier
* RMS Power Output:
o 2,000 Watts x 2 Channels @ 4 Ohms
o 3,500 Watts x 2 Channels @ 2 Ohms
o 5,000 Watts x 2 Channels @ 1 Ohm
o 7,000 Watts x 1 Channel @ 4 Ohms (Bridged)
o 10,000 Watts x 1 Channel @ 2 Ohms (Bridged)
* 2 Ohm Stable in Mono Mode for Subwoofer Operation
* Ultra D-Class Amplifier Topography
* Low Speaker Impedance Stability
* High-Speed MOSFET Output Devices
* RCA Line Outputs: 1 Pair
* XXR-1 Remote Bass Control Included
* RJ45 IN/Out Controls 2-Amps with One Remote Bass Control
* Soft Start Feature to Prevent Turn-on Thumps
* Versa-Cross Crossover:
o Low-Pass Filter: 35 - 250 Hz
o Subsonic Filter: 15 - 35 Hz, 24 dB/Oct.
* Variable Bass Boost: 0 - 18 dB
* Variable Bass EQ: 30Hz - 60Hz
* Adjustable Input Sensitivity: 0.2V - 9V
* Q-Control (Adjusts Wide to Narrow Bandwidth)
* Variable Phase Shift: 0° - 180°
* Balanced Line Input (Use optional XX-BLD Line Driver)
* Quad 2-Gauge Power Terminals
* Protection System Diagnostics
* Overload Protection
* Thermal Over-Temp Protection
* Speaker Short Circuit Protection
* Illuminated Logo
* Amplifier Endcaps Included
* Kilowatt Power From The Gods Included
* Ultra D-Class Benefits:
o Fidelity Improvement Over D-Class
o Low Impedance Load Stability
o Reduced Power Supply Size
o Reduced Heat Management
o Hi-End A/B Class Audio Quality
o High Damping Factor Improves Transient Response
* Damping Factor: >350
* Dimensions: 28" L x 11.2" W x 5.5" H
* 1-year Sonic Electronix warranty
Amplifier Specifications:
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 7000 watts x 1 channel
* RMS Power (2 ohms) 10000 watts x 1 channel
* RMS Power (1 ohm) 5000 watts x 2 channels
* Bridged RMS Power 10000 watts x 1 channel
* Peak Power Output 20000 watts approx.
* Minimum Impedance Unbridged 1 ohm
* Minimum Impedance Bridged 2 ohms
* THD at Rated RMS Power 0.1%
* Speaker Level Inputs No
* Preamp Outputs Yes - 1 pair
* Built-in Crossover Yes - LP
* High-Pass Crossover Frequency N/A
* Low-Pass Crossover Frequency 35 - 250 Hz
* Subsonic Filter 15 - 35 Hz
* Signal-to-Noise Ratio 95 dB
* Channel Separation N/A
* Bass Boost 0 - 18 dB
* Bass/Gain Remote N/A
* Fan Cooled No
* Fuse Rating 1000 Amps
Derp.
Posted Image
Posted Image
:ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r: :ph34r:
is the owner of those hiring because i need a better paying job http://www.stevemeadedesigns.com/board/public/style_emoticons/default/mad.gif
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
i saw some 10k amps at walmart ........................... :ph34r: should have got those ha ha ha great looking amps
dcaudio.jpg ALLAH's the most gracious, he made the universe the most spaciousSeen and heard in all places, but still appear facelessEmbraces all races, all caste and all casesIn every spec of life he's the substance of all tracesSMDsigbannr9.jpg
  • Who's Online   1 Member, 0 Anonymous, 1230 Guests (See full list)
