1point21gigawatts Posted May 29, 2020 Report Share Posted May 29, 2020 4 hours ago, jessdabest77 said: Ok, if I go all the way up to ceiling from floor, I get 35". Same width and depth. Now if I can see both design's. Perhaps 4th ordered. But I'd like to see ported and 4th and your thoughts and suggestions would be great. I appreciate your help and knowledge. I’m not doing 2 designs for free. I’ll design you a 4th order enclosure or a regular enclosure. I thought the width was 46” and depth was 17”? How is it the same? I’m not following. Explain. The measurements I have right now are 46” in width, 17” in length and 35” in height. Correct? I need exact measurements. I have to double check before I start. And which kind of enclosure do you want? Because I can’t design 2 for free, I design 1 out of kindness and being helpful but it takes a while and I like to help but too much is unnecessary unless I’m paid before. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
jessdabest77 Posted May 30, 2020 Author Report Share Posted May 30, 2020 Ok, if I go all the way up to ceiling from floor, I get 35". Same width and depth. Now if I can see both design's. Perhaps 4th ordered. But I'd like to see ported and 4th and your thoughts and suggestions would be great. I appreciate your help and knowledge. Link to comment Share on other sites More sharing options...
jessdabest77 Posted May 30, 2020 Author Report Share Posted May 30, 2020 I do understand time is money and I appreciate any help I can get. I guess I'll just stick with the ported box with measurements of 22 " Height x 17" Depth x 46" Wide meaning from passenger side to driver side. My main goal has always been to play low and loud, much respect and thanks. Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 30, 2020 Report Share Posted May 30, 2020 13 minutes ago, jessdabest77 said: I do understand time is money and I appreciate any help I can get. I guess I'll just stick with the ported box with measurements of 22 " Height x 17" Depth x 46" Wide meaning from passenger side to driver side. My main goal has always been to play low and loud, much respect and thanks. I need the whole width of the rear of cab. Not just seat to seat. I need the whole interior width. I have to factor that in for port reasons. Plus I need you to position your seat the way you usually sit and measure from the furthest point back of the seat of to the back of the cab wall so I know true depth. But I will also keep the enclosure as close to desired measurements. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
CstrokerV Posted May 30, 2020 Report Share Posted May 30, 2020 There’s plenty of people on here that will design. Boxes for free even more than one you just have to catch them on .... and fourth orders are 90% trial and error my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
jessdabest77 Posted May 30, 2020 Author Report Share Posted May 30, 2020 The measurements are perfect for my seat comfortable to drive and 46 " Is the complete width and height is correct for roof or 22" Height if under back window or 35" To headliner. So, 46" W x 17" D x 22" H or 35" If doing 4th order. And lastly just to play low and loud. I started thinking if I did a 4th order where would the port be up top middle or bottom and how. Sorry for thousands of questions but I was hoping this site was for us who love car audio and help everyone and everyone come as one. Link to comment Share on other sites More sharing options...
Joshdashef Posted May 30, 2020 Report Share Posted May 30, 2020 4 minutes ago, jessdabest77 said: The measurements are perfect for my seat comfortable to drive and 46 " Is the complete width and height is correct for roof or 22" Height if under back window or 35" To headliner. So, 46" W x 17" D x 22" H or 35" If doing 4th order. And lastly just to play low and loud. I started thinking if I did a 4th order where would the port be up top middle or bottom and how. Sorry for thousands of questions but I was hoping this site was for us who love car audio and help everyone and everyone come as one. I get a gross footage of 9.96 with a 22" height or 15.84 with a 35" height. I could see a ported box with height of 22" working, or a walled 4th order working depending on the ratio chosen. Generally you choose a 4th order because you want more bandwidth than a ported box. However, you wouldn't be able to tell which would give you the highest output per say without modeling in a program like WinISD or hornresp SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
jessdabest77 Posted May 30, 2020 Author Report Share Posted May 30, 2020 I see. Hopefully someone can help me come up with something. Im not to good with programs but seeing it on paper I can build it. I hope to see a design thank you for helping Link to comment Share on other sites More sharing options...
Joshdashef Posted May 30, 2020 Report Share Posted May 30, 2020 21 minutes ago, jessdabest77 said: I see. Hopefully someone can help me come up with something. Im not to good with programs but seeing it on paper I can build it. I hope to see a design thank you for helping If I had the time I would help design but someone else will help you out the best they can SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
CstrokerV Posted May 30, 2020 Report Share Posted May 30, 2020 Where do you live there might be someone close by ...... my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
