Plz help on box design
13 hours ago, jessdabest77 said:
Hey guys, I've been thinking a lot about my build and here's what I'm thinking. It's a 2003 Chevy S10 Xtreme ext.cab and subs are two 15" FI SP4's v1. I'm thinking of doing a 4th order box, not walling it so that's why I need help. What size box, port size, running, and placement of port, up, forward, or side? I'm running 7 k amp power and good electrical. Any advice, suggestions, and help would be fantastic cause I am lost.
Measurements of available area for enclosure?
:guido:
3 minutes ago, 1point21gigawatts said:
Them subwoofers have an 11” depth and no vent pole. I might be able to design a wall, subs forward, port side. Maybe. I need exact measurements.
He doesn’t want a wall he should be still be able to do subs forward and vent side under window line
Hey guys,ok so I did a rough measurements and got 46" wide x 17" depth x 22" height. I might be able to gain a few inches in width if I remove 3rd seat which I wouldn't mind doing,cause it won't be needed anyhow. The 4th order does sound really good but if I went that route I'd do some type of wall instead of cut through. If perhaps I can see both types of designs that would help me in decide  what I can do. If I can get this to be able to play real low and get loud,I'd be more than happy.Thanks for all the help
With those measurements you get about 10 gross cubic feet. That does not account for the thickness of material, double baffles, bracing, subs, port, etc. If you want to have a box without a wall you have to go to just a ported box. If you are willing to do a wall you could probably fit in a small 4th order
I’ll design you one after I get some rest. You might have to remove the front seats just to get the enclosure in and then put the front seats back on. I’ll know more once I start designing.
:guido:
He won’t be able to run a 4th order enclosure in that cab. Not even a 1:1 ratio.
:guido:
if he walls it he should be able to do a forth those measurements are under window line
I did think that height was short and when I read that I was like, wtf?
:guido:
Did you measure the height from floor to ceiling? If not, then I need that measurement.
:guido:
Ok, if I go all the way up to ceiling from floor, I get 35". Same width and depth. Now if I can see both design's. Perhaps 4th ordered. But I'd like to see ported and 4th and your thoughts and suggestions would be great. I appreciate your help and knowledge.
  • Who's Online   0 Members, 0 Anonymous, 1014 Guests (See full list)
