Fusing Question
hey folks i just recently installed my memphis mch1300, and it's a really good sounding amp. i'm a little confused about what outboard fuse to run. it uses 6 30a fuses and i have a 100a fuse between the amp and battery. is the 100a fuse big enough or do i need more?
spec sheet
5-Channel MClass Series Amplifier
Class-AB / Class-D Hybrid Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
4-Way Protection Circuitry
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
RMS Power Ratings:
75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms
115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms
1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!)
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 25.81" L x 7.6" W x 2.4" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Amplifier Class Channels 1-4: A/B, Channel 5: D
Number of Channels 5
RMS Power (4 ohms) 75 watts x 4 chan. + 300 watts x 1 chan.
RMS Power (2 ohms) 115 watts x 4 chan. + 600 watts x 1 chan.
RMS Power (1 ohm) 1100 watts x 1 channel for the 5th channel (Channels 1-4 Not Stable)
Bridged RMS Power 230 watts x 2 channels
Peak Power Output N/A
Minimum Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5)
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.03%
Speaker Level Inputs No
Preamp Outputs No
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 6000 Hz
Low-Pass Crossover Frequency Channels 1-4: 40-6000Hz and Channel 5: 50-250Hz
Subsonic Filter 20 - 50 Hz
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost N/A
Bass/Gain Remote Optional (Memphis 16-MCRG required and sold separately)
Fan Cooled No
Fuse Rating 30A x 6
Edited by benz280se
spec sheet
Full MOSFET Design
RMS Power Ratings:
Preamp Outputs No
Bass Boost N/A
Fan Cooled No
Fuse Rating 30A x 6
can somebody please just take two seconds and say if the 100 amp fuse is big enough or should i go up?
Edited by benz280se
100a fuse is too small.
The amp fuse rating total is 160a.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
What size wire are you using? That is what determines the fuse size for the power wire.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
See you wont get a quick answer cause you didn't even bother using a search and look for yourself.
Dont be lazy, do some homework.
thanks for your replies right now i am using 4 gauge wire since i had it already in the vehicle, and the terminals on the amp accept 4 gauge. when i get more money and time i'll add 0 gauge, but in the meantime, i will get a 160a fuse then. thank you guys a lot.
i really dont like being an internet smartass but with this long answer you gave, it might have been easier to do this
100a=bad, 160 or larger=good.
less space, question answered, no aggravation :D
Uhhh...
30a x 6 = 180a
You know, I was thinking that number wasn't right...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
  • Who's Online   0 Members, 0 Anonymous, 1311 Guests (See full list)
