New build is having an issue and I can't seem to troubleshoot it
2 hours ago, PooThenPee said:
Ok i will try out the dmm tomorrow. My power and ground are 0 ga. My last system was much weaker and was installed by a shop years ago so i have a feeling i will need to do all these upgrades to get the power im expecting.
These are my battery terminals, the power was just ran from the small stud and there is nothing added to the negative stud. Can i just add a 0 ga from the neg to the chassis and try that? Otherwise I'll have to order more to do the entire big 3, which i will at some point. 20211019_210446.thumb.jpg.64a6ea8128003ad73357ac2419965b4f.jpg
You can try that, but the whole big 3 upgrade will benefit the whole car, not just your system. So the faster you can do it, the better.
Just now, PooThenPee said:
So after wiggling my deck out of my dash I got my model # and it looks like my preamp outs are 2V. Is this my whole issue and if so, what are my options?
It's not a huge issue if you're not having to max out your gain on your amp to match the voltage.
But your options are get our new deck with 4-5v preouts, or a line driver
Sad
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Ok. I am looking at line drivers right now. My amp input sensitivity is 6V ~ 0.2V. I have never used a line driver before but Ill try that. I'll also be ordering more wire for a big 3 upgrade. Thank you.
Like I said, that's not a huge issue. A line driver will up your output voltage, so you don't have to turn the gain up as high to match the output voltage of the head unit, but really, as long as you match that voltage, you'll be getting the same amount of wattage
Very :(
My quick little upgrade is turning into a giant headache
Take that headunit back
06 Charger
Pioneer double din
Xs power d3400
  • Who's Online   1 Member, 0 Anonymous, 1917 Guests (See full list)
