well in the manual it says to fuse with a 250 amp fuse. that means it does 2500 rms at 100% efficiency right?? correct me if im wrong......
amps x volts = watts so if its rated at 14.4.................... 250 x 14.4 = 3600 watts
DC.jpgDC POWER
ive installed a few and still never seen rms on them but still get about 200 out of the 2600 rms model
250a fuse means you'll get 2500rms @ 70% efficiency (about all you're going to get out of Hifonics) and 14.4v without any voltage drop. I've used previous Brutus amps and they haven't ever done rated power. Maybe this one is different. I can't say cause I haven't personally used it yet. I hear these are only good for about 2200watts though. With only a 250a MAX rated current draw I wouldn't hold my breath expecting to see that 2600watts.
you can get the 2608d for around $410 on ebay. i can't seem to find the GP3000d on there. regardless you are getting a pretty good amp for a low price, it's not the lowest amp on the earth and i'll rock one anyday. just wait until i get my missinglink module, they'll put out rated power when i'm done.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i knew i couldnt be right ;) thanks
  • Who's Online   0 Members, 0 Anonymous, 3103 Guests (See full list)
