i THINK i can get this in, and would be more cost effective than two 10s.
specs:
Double Baffle
4.5cuft Net internal volume
two 2x18" slot vents
total 72sqin of port
40hz tuning.
Designed to go behind the rear seats firing fwd sealed off from the trunk. Music preference for this enclosure is Rock/Double Pedal with the woofer seeing ~1200-1500wrms
Just looking for Approval/Disapproval from some of the expert box builders.
-Drew
Edit: just initial draft design, some changes need to be made such as increasing height to compensate for the outer mounting ring of the woofer.
Edited by Noobtastic14
uhoh_45 said:
Thats sick.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
and ur tune frequency wont be exact because the bottom of the port extends beyond the top, so lets says its tuned to 40hz...
include end correction factor if you havent + the port extending at the bottom and its prolly closer to 36-38hz
sweet design and i like two ports, i like the symetry of it
your better off doing 1 4" x 18" port then 2 2" x 18. Those are a little too thin of ports and will probably make noise.
Follow my Tweet (Twitter)
hmmmm...
i'll re-draft a single 4x18" port version.
if the tuning frequency drops a few hz i wont be sad, same effect as the distance between sub/up port/back and the tailgate in an SUV right??
whats a good size for a single 18? reason i opted for 4.5 is because i have my 15 in a compact 2.6cuft box and LOVE the punchy tone it has.
-Drew
I wuold do a 15 rather than an 18" in a trunk. I would still try to do the 2 10"s or 2 12"s though. Even if they are level 3's its still 10x better in my opinion. Your trying to stuff 200lbs of shit into a 5lb bag lol
done the two 10s done the two 12s and currently have a single 15" and love it.
look'n for that lil extra ;)
-Drew
-Drew
With the box space available 2 12"s should shit all over 1 18" because I dont forsee you haveing enough box space.
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
