About to install the subs, and before I do, I would like to make the connections like most of you do and use pass thru bolts. I just went and bought 8 brass 1/4thread x 1 1/2 long bolts and was hoping someone can clue me in on the wiring of it. Do I do a bolt for each V.C, meaning that do I just run a wire from one terminal to a bolt, so each sub will utilize 4 bolts? And just make my connections using eyelets on the outside of the case? If I do it this way, this will use all 8 bolts (thats why I bought 8) or do I just wire the subs inside the box, then just use 2 bolts for the external connections? Thanks Any pics I can see of someones install
I love my staffie :good:
So anti FACEBOOK it isn't even funny
2 bolts per vc. one for pos and one for neg... so you can wire it how ever you want without having to take the subs out.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
So the end result will be 8 bolts sticking out correct? Then just make little jumper wires with eyelets on the ends to jump from stud to stud?
i just built two boxes for each of my DC lvl 4 15s and decided to use bolts and washers. much cheaper way if you ask me.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i would do all 8 just so you can change configutations without taking the subs out. I used for EACH terminal:
in this order
bolt [stick the threads towards the outside]
ring terminal with speaker wire inside
washer
wood
washer
ring terminal and wire
nut
after it was all bolted in, I used some of that "pefect putty" and sealed the inside of the bolt area. It dried really hard and i can't feel any leaks
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
in this order
washer
wood
washer
nut
wrong. u need a nut on the outside of the box before the ring terminal. how would you get the wire off without the bolt turning? you cant.
do what he said on the inside, but the outside do:
washer, nut, ring terminal, washer, nut.
you can put a washer before the ring terminal, but you dont have to.
X2
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
  • Who's Online   0 Members, 0 Anonymous, 3135 Guests (See full list)
