For running a car audio setup in your room. Instead of using batteries/car chargers/PSU's.
Couldn't you put a real car alternator in your room and whip a little device together that spins a belt at 2krpm to spin the alternator pulley.
Then from there, run your normal + wires and ground's to the amplifier.
Thats a dumb theory...but it could work couldnt it? just throwing ideas out there
Guest aseanj52
Sounds like it would be fun to try. a little dangerous.....needs a :ph34r: or you could be a little :wacko: for thinking of it. lol
good luck finding a 5hp electric motor that runs on 115v
You will Smoke your amp if you Hook it directly to an Alt!
I would just get Some battery's And Just bust out the batt Charger!
thats what i did 40amp charger with 2 batts
Im a scamming little cunt rag. i like penis, cum more penis, oh and did i mention penis.
i suck at life....
the 2000rpm's you always read about is the motor rpm, the alternator rpm is A LOT higher because it has a tiny pully. I want to say alternator rpm is something like 5000+rpm's.
so finding a motor to spin your alternator way above 2000rpms is going to be a bit of a challenge I think
why would hooking an amp straight to the alt be a bad idea? and hooking up batts to that would fix it, no?
plus its just a theory, but you never know. maybe someone is crazy enough to try it :)
Edited by Krannyman92
I have 6 or 7 sitting right next to me.
Heres what you do.
You need
1 washing machine motor. Free from the dump.
harbor freight lathe pully
Good GM one wire alternator.
1 car battery.
Now your going to want to figure out how many rpms your washing machine motor turns. Normally you want a ratio of 1 1/2 to 1 or 2 to 1
So shop around for the proper size pulley 1 1/2 times or 2 times the size of the alternator pulley. You don't have a lathe like i did so your gonna have to magivor the pulley onto the motor some how.
run the 1 wire from the alternator to the battery then run the ground from the battery to the the chassis of the alternator.
for the mounts Ive used any thing from 2 vises to a 2 by 8 piece of wood with some steel bolted to it.
Hope this helps :8)
Yes you can, they made one in my electricity class last year, fan blower motor, and pulleys, car battery, with a plug.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
For the time and effort (not to mention noise!) you could probably just get a big-ass switchmode power supply.
Then again if you had the bits sitting around I don't see how it wouldn't work :P
10.x volts fo' life!
