i need to cut 16.75" circles for meh subs, but home depo didnt have anything for drawing circles that big.....i bought a drawing compass for the aero holes but i need something for the big ones like a big a55 drawing compass
.......opinions?
the gasket from the sub works if you have nothing else. just make sure they are a perfect circle tho "thats where a tape measure comes in"
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
Get a scrap strip of wood. Predrill a hole and put a screw through it then 8.375" away predrill another hole and put a screw through there. Shoot one end of that into the center of your sub location then use the other screw as a scribe to mark the cutout.
Another way thats a lil more difficult to get exact. Get a piece of speaker wire and put a small ring terminal on each end so that each ring terminal is exactly 8.375". Screw one end to the center of your sub location and use a pencil in the other to draw out your circle.
The easiest way. Get a Jasper jig and router.
If it's for one use only, take a piece of mdf or any other scrap wood and make a pilot hole and use a bolt or something that you have the right size drill bit for and make that your pilot hole.
Let's say you use a 1/4" drill bit. Find a carriage bolt or something with a head on it that is 1/4" in diameter to hold the 'jig' in place. Then measure half of your distance on the wood, mark it and drill a hole for a pen or anything else you have that will fit through the hole to mark the circle. Fairly simple to make, but if you're going to be cutting different size sub holes, invest in a large compass.
Grr beat me to it! :)
1 screw + tape measure+ 18gauge wire+ ring terminal= perfect circle
make your x for your center, from the center mark measure out 8 3/8"s make 4 marks around th center of your X
screw your screw into your center mark, hook your ring terminal to your screw, put your pencil on one of your 8 3/8s mark pull your wire tight and use the wire to guide you around.
thats how I do it.
I have used a strip of wood,it works better with a pencil on one end and a screw at the center of the sub hole.I have also used a drywall hole cutter,it just barely works for a 18" sub
Assman Idustries
Fear The Duck
Team Notoriously Loud Mafia
Just buy a compass with extension arm, i use one for engineering drawings :)
Previous: 1988 Nissan Patrol
Rockford T800.4
Rockford T1 15 (sealed)
Rockford 6.5 Components
Current: 1997 Jeep Wrangler
Build goals...
1x RF P300.2
4x Hertz HCX165's
Built Completes :)
Alpine 9886 Headunit
RF P300.2
RF P500-1bd
2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz
4x Hertz HCX130's
Current comment...
Satisfied for the moment, focusing on performance upgrades
