S12X Posted December 24, 2006 Report Posted December 24, 2006 i dont think they make 4/0 wire for car audio uses, that stuff is MASSIVE and the only 4/0 wire ive heard of is welding wire and it is not flexible whatsoever Quote new setup in the works
Guest MegaloManiac Posted December 24, 2006 Report Posted December 24, 2006 what kinda cables are you using? You should use 0awg to the 2nd and 3rd batteries as well. Quote
S12X Posted December 24, 2006 Report Posted December 24, 2006 try to use the same size wire for everything...and remember the saying, bigger is better Quote new setup in the works
Slinky Posted December 24, 2006 Author Report Posted December 24, 2006 what kinda cables are you using? You should use 0awg to the 2nd and 3rd batteries as well. I have kicker flex cable Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
ChevyBoy Posted December 24, 2006 Report Posted December 24, 2006 what size alt do you have? i have the same amp, 2 batteries, all 1/0, 200 amp alt, and my voltage WONT drop into the 13's when im driving around bumping. Quote
AI James Posted December 24, 2006 Report Posted December 24, 2006 honestly 4 guage is plenty, if all hes doing is adding to the preexisting stuff there should be no way that 4guage wire added on is hindering him in any way Quote
Ray Posted December 24, 2006 Report Posted December 24, 2006 1/0 wire for everything, get a big alt, and make sure all your batts are good. no fucking way you dip voltage like that after.. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
dmanson Posted December 25, 2006 Report Posted December 25, 2006 1/0 wire for everything, get a big alt, and make sure all your batts are good. no fucking way you dip voltage like that after.. x2 Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Slinky Posted December 25, 2006 Author Report Posted December 25, 2006 what size alt do you have? i have the same amp, 2 batteries, all 1/0, 200 amp alt, and my voltage WONT drop into the 13's when im driving around bumping. Stock 90 amp alt I think im gettin a 180 amp one from excessive amperage Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Slinky Posted December 25, 2006 Author Report Posted December 25, 2006 1/0 wire for everything, get a big alt, and make sure all your batts are good. no fucking way you dip voltage like that after.. Thanks man. Im gonna run some big ass wire to my batts in the back and buy a 180 amp alt and i know for a fact that will solve it. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
