That's good. Now he won't have to feel bad for telling you wrong and you actually doing it, he just has to feel bad for telling you wrong.
nah
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
probably too late now but i personally woulda put that bitch in and rolled it......the big three can be done later.  Especially if your only running one RF T2000.1 for your subs.
Follow my Tweet (Twitter)
THANK YOU AND GOOD NIGHT!!!!!!!!!!!!!!!!!
DD M4
Good news, i put it in! Bad news, voltage is droppin even lower! It took me almost 3 hours to do it cuz it started gettin dark and it was hard for me to get to. first problem was gettin the old one out. second was the wheel on the new alternator. it was smaller than the original so my belt was lose when i installed it. Then i had tha guy at advanced auto parts switch tha old wheel to tha new one. Ok.. got it hooked up, turned on tha car 14.5v! hooked my amp back up(not turned up, jus connected) turned my lights on and...13.3v...12.7v...11.2v. Disconnected tha amp again and it still dropped.On tha way home i got stopped at a light and it got down to 9.8v! :^ as long as im on tha gas at about 1600rpm and above i get 14.1v-14.5v but as soon as i let off it jus continues to drop! i think it might have somethin to do wit me switchin tha wheels but if its somethin else, please let me know!
1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock jtte2o.gif
I also think it has something to do with switching the wheel. The wheel is small for a reason...
a smaller wheel will spin faster than its larger counterpart at any given engine RPM.
So you pretty much dropped the alternator's effective idling RPM by making the wheel bigger.
Damn, you beat me to it, I was changing a diaper, LoL. You just need to change the wheels back to the way they were and get a new belt that is long enough to fit it.
yep you are correct with your assessment.  the pulley that comes with the new alt is supposed to be used.  you are only slowing the alt down going back to the old pulley.  less rpm's at idle means you need to rev higher to get the proper output of the alt.
put the pulley back on and tighten you tensioner or get a smaller belt.  hopefully that helps ya.
  • Who's Online   0 Members, 0 Anonymous, 4497 Guests (See full list)
