Amature Hour - Revision#unknown - 07/24/10 Solo-Classic's Finished!!!
Damn, that is how you start a build thread. ( with pics of stuff "built" if you will ) ...
good work man. Definitely would get that deadener on the floor if you are gonna stay away from carpet , or rubber factory flooring. You got some nice gear too. and a single cab with three barics behind the seat...should wang.
keep em coming...:)
Thanks man.
Ya guys I already have the deadner. I wanted to tryout the Hushmat but I got Dynamat Extreme for cheap so I went with it.
What I don't have yet is the new vinyl flooring and can't afford it yet. I have already dropped acouple grand into parts and equipment, so I can't shell out to much more rite now. Theres just never enough money. LOL
I have alot patch work and rust prevention and painting to do before I put down the deadner in the cab.
LOL thats the stuff I'm getting lazy on.
LOL theres still a 4th L7 in the house. HMMMM
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
:clapping: ya know that cheaper roll on bedliner works pretty good on a metal floor also...
Ya know I have been wondering about that stuff for along time.
I would just be careful with it in the driver and passenger side floorpans. Wouldnt want that stuff wearing down and endin up on your shoe and then taking it into the house and staining tile/carpet/hardwood/linoleum .... maybe see what the local line-x guy would charge you to just do your footwells...probably could do it on top of the deadener and you know linex/rhino liner stuff wont wear down.
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
Wow lookin pretty good. I just hoped on to see if I had any messages and seen this build and started going though it. I like so far. Keep up the good work.
a million points for ISO. this build thread is great and its only started today
good work
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
To fill the holes one of the little things I do is use my MDF saw dust poweder and mix it with wood glue. It actually works really good as a filler.
good tip im going to try that
good job on the build too
so you like that 50 farad cap eh?
ive always wanted to get my hands on one of them big caps like that.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
Ya man it has turned out to be a nice addition. What happened was someone didn't label it rite on Ebay and I won it for $75 almost new.
I think MSRP was $650 so they probbly sold for arounds $500 new. I lucked out on that deal.
You do need the rite chargeing system to back one up though. If you look at my charging system you will see I'm set up to run my 1501BD without it with very little current drop.
It just really helps keep my bass tight and snappy. I just recently ran my amp without it and things overall just didn't sound as good.
I do only recommend an item like this for a music playing system as it does discharge way to fast for use with test tones.
The main spec I looked at after I got it was the one that said the 50 farad cap will sustain 75 amps of DC current for 5 seconds and my amp is supposed to pull around 90 amps playing music. To me that equalls a good match but when I add the third subwoofer I will be pulling more current so I will probbly need to add another battery and still keep the cap but if it is doing what I think its doing its worth it.
Cool setup. The box is sealed am I right, I can't remember.
I always wanted to try the Kicker square subs.
Oh BTW,
http://www.lmctruck.com/
Good for parts for you truck. I haven't dealt with em yet, but even just looking through the catalog sometimes you can figure out how stuff goes together and decode different numbers or whatever.
I think my truck might have LMC parts on it since its got an aftermarket rad support and passenger fender.
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
