are they somewhat like their db amps that do close to rated power? id like to see the innerds of one. ;D
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
seening the other amp back today, no querstions asked......then ordering the xx colossus the day they get it.
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
i am
sorry new set of amp choices,
SundownSA2-1500D
4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v)
2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v)
1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8v)
.5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
.35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v)
Incriminator Audio 20.1
Power Ratings: 1800 watts x 1 at 1 ohm
                900 watts x 1 at 2 ohms
                450 watts x 1 at 4 ohms
Hifonics Colossus
    *  600 watts x 2 chan. @ 4 Ohms
    * 1100 watts x 2 chan. @ 2 Ohms
    * 1600 watts x 2 chan. @ 1 Ohm
    * 2000 watts x 1 chan. @ 4 Ohms
    * 3200 watts x 1 chan. @ 2 Ohms
are those new power acoustik sl amps any good?
I made a thread about them...They're fairly new so nobody really knows much about them.
my build on my buddies jeep is gonna be in a week or two so ill let you know then!
SundownSA2-1500D
Hifonics Colossus
why did you only show low ohm ratings for the sundown, most Colossus do 3800+ at 1ohm.  and some IA20.1s have sick power at low ohm loads
because i can't run the colossus at 1 ohm only 1.4 or .35.. and  the 1.4 turns into 2.5 really quick. I think the sun will be the best choice.over all. I know that it will hold at .35. plus  with i will be able to get a hc2400, 20ft 1/0, alarm and so other thing with my sonic bucks, and save for the sundown. I  will go with the sundown at .35, and have the werker battery up front and a hc 2400 in the back.ho alt will be ordered end of FEB.
meh GL with the sundown they are great amps, i myself just would rather run a Colossus on one or somethign with more power
  • Who's Online   0 Members, 0 Anonymous, 11510 Guests (See full list)
