NASA Selects Term-LAB to Measure Shuttle Launch
NASA has recently selected Term-LAB to measure the Sound Pressure Level generated by the Space Shuttle during liftoff. According to NASA engineers, acoustical measurements during liftoff have not been attempted for more than a decade. And, even then, reliable measurements were difficult if not impossible to achieve due to the extreme nature of the SPL being produced. After researching the available test equipment on the market, Term-LAB was selected for this very demanding application.
NASA plans to use the measurements recorded by Term-LAB to identify specific frequencies that could be causing damage to the pad during launches. The need for logged data required some significant additions and enhancements to the Term-LAB software. Wayne Harris, president of WHE Inc., worked closely with NASA engineers to develop these changes.
The first measurements were taken during the launch of Discovery on May 31, 2008. The sensor was attached to a high-speed camera mount located 1300 feet from the launch pad. The Term-LAB system was switched to “NASA Mode” and the data logger began logging measurements to the computer’s hard drive several minutes prior to liftoff.
The logged data was then reviewed by NASA and WHE Inc. Based on this data, the shuttle established a peak “dB Drag” SPL of 147.7 dB at 20 Hz. While a score like this won’t set any dB Drag Racing World Records, it is very impressive when you consider that the measurement was taken from 1300 feet away and that the frequency where the maximum SPL occurred was 20 Hz.
http://www.termpro.com/hnews/newsdetail.asp?ID=69
That's badass!
A shuttle launch is widely considered to be one of the loudest things on earth!
Definitely something I want to watch in person in my lifetime!
147 db at 20 hz and 1300 ft from the source! :shok:
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
Wonder what it was at the source :o 160+ at 20Hz? maybe 170? yikes...
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
it was 160db before from the same distance, using a BK meter, last I heard
dont know if it was 1300ft on the dot, but it was 160db on the previous mic
147db @20hz would be pretty funny to get a taste of
My memory is about as long as my D@#$, But wasn't there a post about some meter that used the metal box as the mic because the metal was sensitive to pressure diffs. And you had to put a dmm on the metal box? I thought in the thread the rep said that is what nasa used because it had a huge upper limit and was super sensitive.
Edited by alvitae
i ised to live like a mile from where they launched the shuttle. i could hear it from my back patio.
----reference's----
meade916
