x2^^ we had the same prob so i replaced the switch and it fixed it, ied try takein the light down, but first of all turn off power the the light and check for volts befor u start fukin with it or u'll come out lookin like uncle festus lol, and after that ied see if the wires came loose, and if they have make sure there bent around the screw goin in the clockwise direction, if there in the conter clockwise direction when u tighten the screw it will pull the wire out from behind the screw and it will come loose, and ur best bet for replaceing the wire is the junction box and maby some conduit flex with some 14guage stranded wire make sure u get black, white and green, and make sure u ground the box with a pigtail from the ground wire also from the romex should be solid copper and replace the wire if its broken or coroded, but if not maby a simple light houseing change will work?, but ied do switch first, then light houseing, then wire and if that dont work ghosts ftmfl
HAHAHA lol ghosts :D
First thing I would do is pull the light fixture down and make sure the stranded wire is wire nutted (twisted together propperly) to the Romex (solid wire) propperly.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
lol ghosts....
if you have a decent knowladge of elec then if it does need the wire replaced its not hard to do or expensive, maybe 35-40 dollars for a roll or romex and junction box (if you have to splice into the wire) and shouldnt take but maybe a hour or 2 to complete, but i would do the switch first and then the fixture then the wire when all else fails
Agreed.
Remember, House Wiring is opposite of vehicle wiring.
Your BLACK is hot and WHITE is Neutral.
Green is Ground.
lol ghosts....
would the switch still be a possibility if the other lights off the switch don't have this problem? just one particular light, out of two or three on one switch.
Agreed.
Green is Ground.
yuppers.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
there are a few things that could be the problem,
1. bad switch or going bad =$.50 replacemt
2. bad light assembly and just needs to be replaced due to age and over heated internals $7-15.00
3. rodent has half way chewed thru the wires $take loan out and let the pros deal with that crap lol...
I wish switches were only $.50 ya its probably a bad ground if it does it when you walk then its most likely just a shit wiring job thats causing vibrations and knocking something loose
First thing I would do is turn the electricity off.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
well duhh... that's kinda obvious
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
if there are more than 1 light on the switch, but the other 2-3 are fine then i would say its just a failing light fixture and very simple to fix
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
  • Who's Online   1 Member, 0 Anonymous, 1433 Guests (See full list)
